Scanner Recommendations for Hattiesburg
I'm looking to buy a scanner that can pick up Hattiesburg and Forrest county. I would then like to provide a feed on Radio Reference. Any recommendations?
Also does anyone know if I can provide a feed through by Mac? Or does it have to be through a PC?
MS Gulf Coast
#3
It's hard to recommend anything not digital capable and in doing so that narrows down your choices quite considerably. Basically it's a choice of whether you like Uniden's or GRE's way of storing data the most.
As far as feeds go you'll need to look at what is already being provided and see what gaps you would be interested in filling. (if any) What would totally awesome if you could provide a MSWIN feed for that area. :)
