SCANNER SHOPS. BCT15XT Program jack broke
ScanMaine
Lewiston Maine
Im looking for someone who can change the programming adapter on my BCT15X The pins in side are all messed up and I cant program the scanner, I need it asap and a quick turn around so im not really interested in sending it to UNIDEN.
THanks
N9JIG
Sheriff
Moderator
Far NW Valley
While I know your problem has been resolved, for the others interested in this issue you can program many of the Uniden scanners with the rear DB-9 using a null-modem adapter or cable and either a serial port on your computer or a USB-Serial adapter.
While I know it works with the BCT15, BCT15X, BCD996T, XT and P2, I haven't tried this on a BCD536HP though it should work for Serial Mode.
The front serial port and USB ports are easily damaged. I have broken a couple of them over the years and used the rear DB-9 instead when needed.
For my 996XT's in the truck I installed a 3.5MM stereo jack on the rear panel to use with the RH-96. I have not tried programming with this jack however. (The RH-96 will also work on the rear serial port with a properly constructed cable on any of these except the 536 and P2.)
https://www.amazon.com/SF-Cable-Nul...d=1481943034&sr=8-2&keywords=null+modem+cable is a serial cable that would work with a serial port or a serial to USB adapter.
https://www.amazon.com/StarTech-com...d=1481943034&sr=8-3&keywords=null+modem+cable looks interesting. It is a USB-serial adapter with built-in null modem adapter. While I haven't tried it myself, it should do the job directly with no other adapter.
ScanMaine
Lewiston Maine
while i know your problem has been resolved, for the others interested in this issue you can program many of the uniden scanners with the rear db-9 using a null-modem adapter or cable and either a serial port on your computer or a usb-serial adapter.
While i know it works with the bct15, bct15x, bcd996t, xt and p2, i haven't tried this on a bcd536hp though it should work for serial mode.
The front serial port and usb ports are easily damaged. I have broken a couple of them over the years and used the rear db-9 instead when needed.
For my 996xt's in the truck i installed a 3.5mm stereo jack on the rear panel to use with the rh-96. I have not tried programming with this jack however. (the rh-96 will also work on the rear serial port with a properly constructed cable on any of these except the 536 and p2.)
https://www.amazon.com/sf-cable-nul...d=1481943034&sr=8-2&keywords=null+modem+cable is a serial cable that would work with a serial port or a serial to usb adapter.
https://www.amazon.com/startech-com...d=1481943034&sr=8-3&keywords=null+modem+cable looks interesting. It is a usb-serial adapter with built-in null modem adapter. While i haven't tried it myself, it should do the job directly with no other adapter.
thanks again n9jig
