Scanner Sleuthing: Detecting frequencies by RF field
Gilligan
Hagerstown, MD
I have read in the past that it's possible to determine the frequency of a two-way radio that is very close by searching the bands and waiting until you hear what sounds like a scanner birdie. Something like this:
Target two radio radio actually operates on 464.500. You scan 450 - 470 and scanner stops on 453.800 w/ no audio. Add 10.7 (common IF) to find actually frequency without hearing any speech.
I kind of doubt that this would work but I think I read it about ten years ago on Stupid Scanner Tricks or somewhere. Anybody ever tried it successfully? Any ideas?
W4KRR
Coconut Creek
If target radio operates on 464.500, why not just scan and wait until the radio stops on....464.500? What's the purpose of all the added nonsense?
w4rez
Parkersburg, WV
Because then you have to wait until somebody keys the radio to transmit. The IF birdie comes from the Rx section, thus causing the radio to transmit a weak carrier at the sum of the Rx and IF frequencies.
mancow
N.E. Kansas
Basically you are referring to Tempest Monitoring.
http://tinyurl.com/fbjt5
I have seen some highway patrol units with a box that is a Radar Detector Detector. I believe it operates by listening for certain IF frequency emissions.
Gilligan
Hagerstown, MD
This is what I'm talking about... Has anyone actually got it to work?
kb2vxa
Banned
Point Pleasant Beach, N.J.
Hi Gilligan and the castaways,
So far Ginger doesn't know, Mary Ann is just too cute for cognative thought, the Howells only know about money and the skipper is, well, the skipper. That leaves you with the professor but can Little Buddy fathom the answer?
Put de lime in da coconut an' drink 'em bo' to-gedda.
Uh, sorry, wrong island. Now let's get down with the local oscillator that heterodynes with the incoming signal in the mixer stage following the RF amplifier to produce the first intermediate frequency (IF). That's the theory they're stabbing at but don't quite have it right, that oscillator may radiate a weak signal for a very short distance, a couple of feet at most. In a worst case scenario (really crappy receiver without an RF amplifier stage) it may back up through the antenna and go a bit farther but not by much. This is what causes some scanners sitting side by side to lock up on a "dead carrier" that some incorrectly call a "birdy" which is actually a spurious product of a crappy receiver, it locks up on itself.
Now you have the "theory of operation" let's take a look at the radio you're trying to figure out. Like I said a scanner for example might radiate for a few feet, a proper receiver, ham, commercial, etc. won't radiate at all. There goes your stupid scanner trick, myth busted.
Someone mentioned radar detector detectors but first let's examine the front end of a receiver. In a good receiver the signal passes through an RF amplifier before entering the mixer where the local oscillator signal is injected. The mixer output passes through a tuned circuit which selects one of four mixer products and sends it ti the intermediate frequency amplifier. In a dual conversion or triple conversion receiver this process is repeated two or three times each producing a lower IF and thus greater image rejection as the succeeeding tuned circuits filter them out.
Please note the RF amplifier stage effectively isolates the mixer and local oscillator from the antenna so far less if any local signal is radiated than when no such stage is used. This was the case with the famous "All American Five" 5 tube AM table radios of years gone by when a combination oscillator and mixer called a converter was fed by the antenna directly. Cheap "transistor radios" used the same IF conversion scheme as did many cheap shortwave and VHF receivers which were notorious for television interference, they radiated like little transmitters. I know, one was my first "scanner" back when they had tuning knobs and radio dials.
Now we FINALLY get to the radar detector detectors, whew. The crappy old radar detectors operate on the same principle using a Gunn diode self-oscillating converter mounted on a panel antenna which radiates a strong signal. This signal is picked up on a sensitive microwave receiver and it's relationship to the radar frequency reveals it as coming from a radar detector rather than some other microwave source.
Just an intersting footnote, early Neilsen TV ratings polls were done electronically from a truck going slowly down the street. It contained a sensitive receiver and spectrum analyzer hooked up to a recorder and used the signals from the local oscillators in TV tuners to log which stations they were tuned to and whether or not they were operating. At the time nearly every home had a TV set so with statistical error correction a reasonably accurate survey could be taken.
That's your lesson for today dear castaways, now get busy with the vines and coconuts and build a generator to power the transmitter I just made from Ginger's transistor radio. While you're doing that I'll be wondering why the boat engine never had an alternator and battery system or that fat pork never put in a marine radio. What a stupid show, at least Ed Wood's movies made sense, sort of.
