scanner useful?
citylink_uk
There are no scanners on the market that have in-built support for tracking MPT1327 systems. There is free software available (such as 'Trunkview') that will allows advances tracking, talkgroup filters, recording etc. However, this obviously limits you to monitoring from a static location with a PC and serial lead.
Gator596
Niagara Region - Canada
You should be able to.
With the MPT-1327 system I had experience with I just programmed in whatever freqs were listed. The major down side was you heard everybody that was on the system - you couldn't select who you heard.
morfis
well the system only has one freq so ...............................I can monitor it open me thinks?
If there is a single voice frequency then you'll be able to monitor it fine with your 780 but you'll hear the control data between voice transmissions which will get annoying. If it uses a control channel with a separate single voice frequency you'll be spared most of the control data.
The software that Rich mentioned, Trunkview, does offer some nice features even if there is only one frequency - easy logging of radio IDs, locking out IDs you don't want to listen to, mapping the call usage.
For larger systems then the software really makes monitoring a lot more pleasant than simply scanning the known voice frequencies.
DCMon
Oregon
I use trunkview and it works well. I hook up one scanner via audio cable to the computer soundcard and another (396XT) via serial/usb and it tracks the calls.
