I recently purchased a Pro197 that I'm trying to stream using Scannercast.
Scannercast randomly reports "Not communicating with scanner". It starts up OK and may work fine for several hours or at times only a minute or two. I then see the Scannercast scanner connection status rapidly flashing back and forth between "OK" and "Not communicating with scanner".
I also have a Pro106 that does NOT exhibit this problem using Scannercast. It works great.
I have tried two different USB-serial cables, three different computers(xp & win7). All act the same way when I use the Pro197. I tried using the 197 with Win500 to stream. That combination works fine.
Is my Pro197 defective? Or is there a setting I've overlooked causing this problem?
Any ideas?
Any ideas?
