Scannercast
kce264
Wilbraham MA
I am trying to get a feed up and running but Scannercast keeps shutting down after a few minutes. It was pretty much a plug and play install and when its up it streams just fine. The power scheme is "always on" and the network connection is set for always on.
I'm going on the assumption that i am missing something obvious and hope someone can point me in the right direction.
kce264
Wilbraham MA
Thanks for the reply. The problem was just as simple as I thought, my computer randomly shuts down and restarts.
Go figure.
