Scanning Conventional channels in IP Site Connect channels
Jakc_dmt
Does anyone have a procedure or a workaround to enable scanning a conventional digital channel into an IP Site Connect Channel?
Jakc_dmt
Thanks K2NEC. The conventional channel is not IPSC enabled. We want to hear this conventional channel in our IPSC channels. Is there a way to include a conventional channel in the Roam List? We do not us Cap. plus just digital channels.
Jakc_dmt
I see this in the CPS programming. I was hoping for a workaround. Users monitoring between IPSC and conventional now each carry 2 DP4401EX radios and it is not very handy. Thanks again.
K2NEC
NA
If the conventional channel is not a part of the IPSC system, ie two seperate repeater systems with seperate traffic, there is no way to achieve what you are trying to do. I would seriously advocate against messing with your work radios. They are setup a certain way for a reason
Jakc_dmt
You understood right, there is an IPSC system for wide area coverage and a separate stand-alone repeater for local area coverage. These systems evolved through the years and simply out of neccesity.
ramal121
Lots and lots of watts
Calif Whine Country
Does the radio differentiate between an ISPC and a stand alone channel? I don't think so but if not I guess you could add the non-ISPC to the roam list but I see this as a really sloppy way to jump off and on to a ISPC system.
Jakc_dmt
Thanks ramal121. Just as K2NEC mentioned, IPSC has a roam list of only IPSC channels, the stand-alone repeater has a conventional TDMA channels found in the Scan List and cannot be found in the Roam List. Since all are digital channels, I was hoping there was a way to combine the two lists.
