Scanning during thunderstorms
xpawel15x
After the heat wave, we have some strong thunderstorm in my area. I want to be scanning during the storms because there usually is a lot to listen to. I was just wondering if it safe to be by a scanner at the time of the storm. Can it possibly attract lighting?
trainman111
Richmond, VA
If you have an outdoor antenna up, I definately would not recommend attaching it to your scanner and listening, whether it is grounded or not. What I usually do is just attach the rubber duckie and listen using that. While you might loose some of the more distant signals, you'll still be able to hear what is remotely close to you.
xpawel15x
I only listen with a portable handheld scanner antenna...Diamond RH77CA to be exact.
captmfa7112
Staten Island, NYC
Attic Antenna
How about an antenna in the attic? Would the same principle that applies to outdoor antennas apply here?
Bucko
Marietta, Ohio
I use my indoor antenna's in the closet and attic all the time during a storm, if it gets them then you are in trouble.
N4JNW
Irvine, KY
Yeah, if lightning strikes an indoor antenna, your scanners being popped will be the least of your worries...
Seriously though, sometimes during a storm, you don't have to be hit directly by lightning to seriously fry sensitive electronics. Sometimes, a hefty static discharge is all it takes to pop your favorite scanner.
While lightning technically is a HUGE static discharge in the atmosphere, a smaller one will do damage as well. It's a good idea to always unplug during a storm. It might be a pain in the butt, but I've learned sometimes pain in the butts save your butt!
As mentioned, throw on a good duckie, or telescopic antenna and continue your scanning adventures. :)
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
and it can happen - even a near strike can induce a large voltage jump in any nearby conductors, and that includes antennas. Frankly the safest thing to do is not listen at all during a lightning storm; why tempt fate? 73s Mike
rdale
Lansing, MI
There's no safety problem with a handheld scanner and a rubber ducky or similar antenna. If the lightning is close enough to fry your scanner in that circumstance, you have bigger issues to deal with ;>
policefreak
Berlin, NJ
Even if the scanner is unplugged, it is running off batteries, and only the rubber duck is attached, can the scanner still receive a power surge from a nearby strike?
motomeso
Ontario
Just don't listen to your hand held scanner under a tree and you will be fine.
N4JNW
Irvine, KY
No. Considering it is unplugged from the power, and the antenna, there is no way it can recieve a power surge. It's not hooked to anything..
trace1
EM73co
You’ll catch me listening to my scanner and HT quite often during inclement weather conditions, all of course being not connected to any outside antenna(s) or commercial power source, being that not only am I a member of the local ARES and RACES I just happen to want to know and keep up with what is going on during this time...
