scanning help astro 25 cps software
wb6sub
Antelope Valley, CA
I have no problem making up a scan list in the software , I set up the buttons with a scan list program and scan button and set up in the software user programming; when I try to manipulate the scan list or set to scan the XTS5000 radios just honk and it never scans. I need help is setting up scanning in the software please.
riveter
MD
Do you get some sort of displayed error when attempting to scan?
Are you trying to scan conventional systems?
Are you trying to scan a trunked system for which you have a valid and authorized key?
Are you trying to set up no-affiliate trunked scanning?
Still a lot of information left that needs to be here ;)
KE4ZNR
Radio Geek
All of the above along with did you assign the scan list to the associated personality (conventional or trunked)?
That is what normally gets forgotten.
Marshall KE4ZNR
Sent from my SM-N910V using Tapatalk
wb6sub
Antelope Valley, CA
This is conventional only I created a scan list and assigned it to a zone that is supposed to scan. When I push the scan button it just does the honk not a beep so I must be doing something wrong. I have not even tried a trunking system just conventional ham systems.
wb6sub
Antelope Valley, CA
The only thing I have done is assign a scan list to a zone with the channels I want to scan. Maybe that is what I am doing wrong because unless that is assigning it to a personality then no, Sorry never used the new motorola software. I appreciate any help!
wb6sub
Antelope Valley, CA
ok thank you all for the help I found the exact location I didn't have the channel in the zone assigned to the scan list
