Scanning NXDN system
mass-man
trying to retire...
Parker Co., TX
will an IDAS portable scan a 4800 baud NXDN system without a system key?
Just need to listen only to one 3 channel system.
If the answer is YES, what portable do you recommend? Need not be new, for an older uncle who just wants to hear his buddies in the volunteer FD.
Echo4Thirty
Colorado Springs, CO
it will scan it in conventional mode, so you will need to lock out the control channel. You also need to know the RAN. I use an Icom for this same usage. I even alias the TGs.
pro106import
Milford, Ct. perched high above Long Island Sound
@Echo4Thirty , curious what radio you are using. I need one that receives a 9600 Type C system 12.5Khz.
I was hoping I can scan conventionally also.
Echo4Thirty
I use a 4161 but it only does 4800 (6.25 kHz very narrow), I do not know of any Icoms that do 9600 12.5 kHz NXDN Narrow. I think your only option might be a scanner with the NXDN upgrades.
pro106import
OK thank You for that info. Yes I do use a Whistler TRX-1 which works great on NXDN but the sensitivity isn't as good as a commercial grade radio and the system I am monitoring is 60 miles away, so I do have problems with adjacent frequencies splashing over ect...
pro106import
Yes so you would program all channels and talk groups conventional and scan them conventually do not program the control channel
you cannot program a type C system without all the parameters this is why the Kenwood radio are all locked down and the icom give you a bit more flexibility.
