Scanning PG&E in the San Francisco Bay Area
PCTEK
Northern California, USA
#1
I see that PG&E will be converting to the MPT-1327 Standard. I'm assuming that none of the present day scanner are able to receive this mode? Is that right? I also liked to listen when our power was out to see what was going on.
Thank you
#2
They have already transitioned in the bay area, but correct, there is not scanner that can follow that protocol. You can still listen in the conventional sense.
