I know that scanning public safety with apx is controversial so let’s not run that tired thread again but from a purely radio perspective and learning about radios why does an apx need a system key to monitor only and a scanner does not?
The software system key I assume is there to basically say, if you have it, the radio is a part of the system. If the radio is a part of the system, it's capable of taking up system resources, conflicting with radio ids, and transmitting on talkgroups. It is also at the same time able to be inhibited by the system, and that cannot be disabled. Essentially a promise, that this radio is a part of the system. Obviously the biggest difference between a scanner and an APX radio, is that a radio is capable of transmitting. While you may only be using the radio for receive, it's still capable to transmit. There are dangers and risks to using an APX radio for the purpose of a scanner. As it does require special programming as to what is called non affiliate scanning. Which is a way to trick the radio to not affiliate, and not transmit on the trunked system. However using this method results in the loss of some features. The APX is not designed as a scanner, and it lacks a lot of features you might want in a scanner.I know that scanning public safety with apx is controversial so let’s not run that tired thread again but from a purely radio perspective and learning about radios why does an apx need a system key to monitor only and a scanner does not?
the Software System Key, is not actually in the radio, but simply required in order to be able to program the radio.
Ok, Dumb question. Is the system key specific to a particular system and issued by Motorola?
I have been researching how to scan p25 p2 with an apx using the non-affiliate method from a conventional channel, and have been chipping away at a codeplug. I have not nailed it yet. When you say "It is possible to interfere with systems if not properly configured" i don't see how that is true. To interfere with the system you have to get on the system and to do that you need a system key, which you have to hack or obtain in some other way that is not cool. You can't get on the system by mistake! Repeat: you can't get on the system without a key, correct? Therefore I don't understand why we are not sharing more freely the technique to scan without affiliating/without a system key. I don't see the big deal here. I like how complicated it is, it is a cool radio and trunking learning project. I am trying to piece it together but the threads are so interwoven with the morals of doing this the research is difficult. It's such a hot potato, there will be 100 posts in a thread about this and literally 10 of them will be about how to actually do it. There is one great post on batlab but it is old and a lot of the youtube videos are on an older version of the cps and are only for P1 so I am stuck right now, I feel like I am a check box or setting away from getting it right. In ham radio spirit I am looking for a mentor if anyone wants to pm me, I going to do this legit or not at all.You do not need a system key to monitor a P25 - trunked system with an APX. It's a pain in the ass to configure but you do not need a key. However... It is possible to interfere with systems if not properly configured, this is the concern. Which is why most of us who know how to configure it, guard the knowledge, thus protecting those who protect us.
APX radios are not engineered to be "scanners" yes they can scan, but not how most Scanners scan digital systems.
I don't think you're getting the hole picture. In order to do non-affiliate scan with an APX radio on a phase II system you need to configure certain trunking parameters within CPS to make it work. The system key unlocks the trunking options in CPS. That's all it does, so yeah you need one for the system you want to listen too. However, after you load the key, if you make mistakes while configuring your radio it could attempt to affiliate with the system. So yes, you can get on a system by mistake. It has happened many times.
Keep reading and be patient, in the true ham spirt. You'll figure it out eventually. If you wanted easy programming you should have bought a Harris XG100P. No system key required and true non-affiliate scan built right into CPS.
If you like I can take a look at the code plug I have programmed many APX for NAS. I’ll just say this you shouldn’t have to mess with many parameters at all.I have been researching how to scan p25 p2 with an apx using the non-affiliate method from a conventional channel, and have been chipping away at a codeplug. I have not nailed it yet. When you say "It is possible to interfere with systems if not properly configured" i don't see how that is true. To interfere with the system you have to get on the system and to do that you need a system key, which you have to hack or obtain in some other way that is not cool. You can't get on the system by mistake! Repeat: you can't get on the system without a key, correct? Therefore I don't understand why we are not sharing more freely the technique to scan without affiliating/without a system key. I don't see the big deal here. I like how complicated it is, it is a cool radio and trunking learning project. I am trying to piece it together but the threads are so interwoven with the morals of doing this the research is difficult. It's such a hot potato, there will be 100 posts in a thread about this and literally 10 of them will be about how to actually do it. There is one great post on batlab but it is old and a lot of the youtube videos are on an older version of the cps and are only for P1 so I am stuck right now, I feel like I am a check box or setting away from getting it right. In ham radio spirit I am looking for a mentor if anyone wants to pm me, I going to do this legit or not at all.
It looks like there are some legal questions which may or may not pertain. If it scan be used as a scanner and not violate the law or put people in danger then what exactly is the problem?
