scanning question regarding Radioddity gm30
Is there a way to limit scanning on the gm 30, like banks or anything? Does it scan all the channels programmed no matter what?
Specifically, is there a way I can just limit the scanning to the gmrs channels? Sometimes I just want to monitor those channels, without the other stuff I have programmed in.
sallen07
Rochester, NY
Yes.
In the programming software there is a column "Scan Add". If you want to scan a channel, set that to "Yes". If you do not, then "No".
808Beachbum
There are no "banks" as a typical scanner. It is all or nothing for memory channels you select as "Yes" to menu item "Scan Add". The only exception, although I have not tried this for the actual GMRS channel freqs, is the "Scan Range". It appears you MIGHT be able to run a scan range on VFO A while VFO B is available for your standby channel ( I have not tried this yet). You definitely cannnot scan on both VFO's at same time... You can run a memory channel scan on one VFO while monitoring the other. I have local Ham repeaters and Marine VHF freqs that I typically scan while monitoring a particular GMRS channel.
808Beachbum
@MonitoringMass , your question is not crystal clear...if you want to know what tone is already programmed into a specific (GMRS) CHANNEL on your radio, use the menu items 9 - 12 to see what is programmed (CTCSS/DCS, RX/TX) on specific channel, or to change that tone on the channel. Or, you can also use menu 30 or 31 to scan for tones on a specific frequency that are transmitted within range, then try those tones on the repeater you want to reach...by trial and error.
