Scantenna (ST2) impedance 75ohm
302HO
Am interested, and have read good things about the scantenna (st2). I read the specs from antennacraft and the output impedance is 300ohm. I think there is a transformer included which then drops the impedance to 75ohm.
My radio - Icom R20 has a BNC 50ohm. Well i guess you know where i am going with this.
Wont the two different impedances create a loss?
Is there a way around this?
Thank you
LarrySC
Greenville, SC
They come supplied with a 4:1 300ohm to 75ohm balun and RG-6 coax. Good VHF/UHF but a little weak on 800. You can add length to long bottom element to drop coverage on low band. Good Luck.
N
N_Jay
Guest
The small difference between 50 ohm and 75 ohm is mostly irrelevant on an receive only antenna system.
