Yaesu: SCU-LAN10
firemantom26
Wintersville Ohio
Good morning,
I just recently passed my ham ticket. I am still waiting on the call sign. I bought the Yeasu DX 10 along with the SCU-LAN 10.
I got the SCU-LAN 10 program to work on my computer at home but I am not able to connect remotely to. I opened port 50000-50003. Also, the software shows main and sub on top of each other but as soon as you connect to it and it goes away. I would like to use the sub and main screen setting. Attachments to explain better. Any help will be helpful.
73’s
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Did you allow incoming connections in windows from 50000-50003 UDP ? Did you set up port forwarding on your firewall to port-forward 50000-50003 UDP on your WAN IP to 50000-50003 UDP on your PC that is running the software?
Mike
firemantom26
Wintersville Ohio
@mtindor I am at work now and I will fiddle with it when I get home. I did find out the reason why the screen changed is the one is for radios with dual meters. I was happy that I was able to get it to work on my laptop just not able to connect remotely.
firemantom26
Wintersville Ohio
Mike, I opened ports 50000-50003 ports using UDP/TCP on my router. The problem was on the receive end / work computer I had to put in the my outside address where it asked for remote address. I did that and now its working. Thanks for your help.
