SDR Dongle Heat
boatbod
Talbot Co, MD
They do get hot while in use, which is why I won't buy any of the "mini" variants because they just don't cool well enough for my liking.
DeaconHarry16
Beckley WV
I found this in a review of the rtl-sdr.com v3 dongle, which i use.
They work well and I have no other experience with any other dongles, just curious.
Thanks for replys...
The new rtl-sdr.com dongle gets really hot, significantly more than previous generation, so raised my concerns with the manufacturer, who replied the following:
"The heat produced is normal, and the V3 is expected to get a little hotter as there is an extra amp in there for the HF circuit, drawing about 20-30mA extra. However, the V3 has much better heat dissipation because we redesigned the PCB to have much larger copper sink areas (in internal PCB layers, which other dongles don't have), and to allow the heat to be extracted via the thermal pad much better. The result may be a hotter case, but cooler insides."
Cooling is not necessary per se, stock dongle performed without hiccup left under the sun in temperatures exceeding 100 Fahrenheit / 40 Celsius degrees for 7 hours, and its brother worked flawlessly for a week on max gain ADS-B duty.
spongella
W. NJ
I've seen a dongle for sale on EBay that has a cooling fan. Mine has a metal case. Not sure what specific part(s) cause it to heat.
VladeDoddy
The V3 RTL dongles I own used to get pretty warm when I had them laying on a wooden shelf. Now I have them laying on top of a CD changer that has a metal case and they are noticeably cooler now. If you have something metal to set it on that might help dissipate the heat
