Sdr & dsd+ dmr
Quilmes, Buenos Aires, Argentina
#1
Hello everyone, I would like to monitor my DMR Mototrbo system that has built-in privacy settings, I have managed to monitor but I can not enter my privacy code to listen to the network traffic. Is there any way to do it using the command line ?.
Thank you very much.
Greetings.
#2
Greetings.
No it won't do that, you'll have need to modify the DSD source and XOR the ambe voice frames with the BP key.
