Sdr sharp not fitting my laptop screen
pdeveau2010
Tewksbury,MA
HI
I am running a laptop with the max res set at 1366 x 768 when i run sdr sharp almost everything in the left hand collum ( plug ins )fits but not everything, i am not seeing some of my check boxes or even any choices to select .
is there anything i can do about this.
Paul
1. set your taskbar to "auto-hide". Use the Windows key any time you want to see your task bar.
2. collapse the plug-ins you aren't using.
3. check the "Frequency Manager + Scanner" plug-in for an update. It looks to be hogging too much screen width
4. get a bigger laptop (just kidding).
This next one won't help visually but ...
5. set the FFT bin size smaller - less CPU loading, more responsive laptop.
I have the "Frequency Manager" plug-in, not the "Frequency Manager + Scanner" plugin so I'm not seeing this issue.
pdeveau2010
Tewksbury,MA
hi, thanks for all the info, I fixed it, seems my fonts were not on default, put them at 100% and eveything went back to normal. thanks again everyone.
