If you mean that you're using the same antenna
at the same time with both receivers aka you've got a splitter or Y-type connection somewhere in the antenna cabling/wiring then part of the problem is the moment you split the antenna's feed you cut the signal strength literally in half that's reaching each receiver. As noted in the post above, physical scanners are traditionally sold with the RF gain set to a level at the factory where it's determined to be able to provide the best chance of receiving a signal without overloading the front end - they almost always have an attenuator circuit that can be turned on or off as required in a really strong signal area to prevent that overload, but scanners have never really had a "signal boost" type amplifier circuit in them.
Because of this and knowing that most SDR applications support altering the RF gain across a pretty wide range - most of the "cheap USB TV tuners" we all use nowadays aka RTL-based sticks offer up to 49 dB of gain means that in some situations you'll probably be able to get a good signal with that level of control over the gain as compared to the physical scanner with gain you can't do anything with.
While I'm not absolutely positive, as I mentioned above if you're using a splitter to share one antenna with two receivers at one time that's a 50% signal reduction to each scanner compared to what it would be if one receiver at a time had discrete access to the antenna.
Now it remains to be seen what the situation is so I suspect we'll get an update with that info soon enough.
