I have used RTL dongles for many years now and want to venture out to see what else is out there. I have pretty good results with my RTL dongle and OP25 in the city (mostly) but when I go home it does show that it is a cheaper SDR. Now for reference, I have problems where I'm at with normal scanners and even professional radios at one point.
I use a Unication G5 with a blue antenna for the 800 MHz range and get VERY good results. Before I venture into filters and other physical means to tune out noise (because I believe the signal from the radio tower is having a harder time with the hill about half a mile away rather than just noise), I want to see what higher end SDRs are out there that work with OP25 and are comparable to a professional radio or pager. I will also use this for experimenting with other RTL dongles.
Sent from my SM-G975U using Tapatalk
