I have investigated more
and connected to the same computer hackrf instead of the rtl-sdr didnt touch anything in the software just run it again
and all seems to be stable
so i think the problem is in the driver of the rtlsdr in the software
it work for some time and then it start to loose decode and even doesn't decode the control channel
here is the logfile according to the explain you told me where to find it .
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - SDRTrunk Version : 0.5.0-beta5 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Gradle Version : Gradle 7.4.2 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Build Timestamp : 2022-07-23T08:15:59.564-0400 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Build-JDK : 18.0.1 (BellSoft 18.0.1+12 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Build OS : Linux (amd64 5.15.0-41-generic [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - ******************************************************************* [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application *** [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - **** website:
GitHub - DSheirer/sdrtrunk: A cross-platform java application for decoding, monitoring, recording and streaming trunked mobile and related radio protocols using Software Defined Radios (SDR). Website: *** [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%] [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host OS Name: Windows 11 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host OS Arch: amd64 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host OS Version: 10.0 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host CPU Cores: 8 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host Max Java Memory: 1 GB [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Storage Directories: [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Application Root: C:\Users\ronen\SDRTrunk [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Application Log: C:\Users\ronen\SDRTrunk\logs [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Event Log: C:\Users\ronen\SDRTrunk\event_logs [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Playlist: C:\Users\ronen\SDRTrunk\playlist [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Recordings: C:\Users\ronen\SDRTrunk\recordings [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.dsheirer.util.ThreadPool - Application thread pool created SCHEDULED and CACHED executors threads [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.github.dsheirer.gui.SDRTrunk - Home path: C:\Users\ronen\SDRTrunk [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\ronen\SDRTrunk\SDRTrunk.properties] [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\ronen\SDRTrunk\SDRTrunk.properties] [20MB/128MB 16%]
20220730 225717.399 [main] INFO i.g.d.s.t.manager.TunerManager - Discovering tuners ... [8MB/27MB 31%]
20220730 225717.477 [main] INFO i.g.d.s.t.manager.TunerManager - LibUsb API Version: 1.0.262 [9MB/27MB 35%]
20220730 225717.493 [main] INFO i.g.d.s.t.manager.TunerManager - LibUsb Version: 1.0.22.11312 [9MB/27MB 35%]
20220730 225717.508 [main] INFO i.g.d.s.t.manager.TunerManager - LibUsb - discovered [5] potential usb devices [9MB/27MB 35%]
20220730 225717.524 [main] INFO i.g.d.s.t.manager.TunerManager - Discovered tuner at USB Bus [1] Port [2] Tuner Class [RTL-2832] [10MB/27MB 37%]
20220730 225717.524 [main] INFO i.g.d.s.t.manager.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:1 Port:2 - Added / Starting ... [10MB/27MB 37%]
20220730 225718.971 [main] INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [13MB/27MB 50%]
20220730 225718.971 [main] INFO i.g.d.s.t.manager.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:1 Port:2 - Applying Tuner Configuration [13MB/27MB 50%]
20220730 225719.283 [main] INFO i.g.d.s.t.manager.TunerManager - LibUsb Hotplug event notification Is Not Supported on this platform. [14MB/27MB 51%]
20220730 225719.299 [main] INFO i.g.d.settings.SettingsManager - SettingsManager - loading settings file [C:\Users\ronen\SDRTrunk\settings\settings.xml] [14MB/27MB 51%]
20220730 225719.637 [main] WARN i.g.d.vector.VectorUtilities - CPU supports maximum SIMD instructions of Species[float, 8, S_256_BIT] [9MB/29MB 32%]
20220730 225720.209 [main] INFO i.g.d.playlist.PlaylistManager - Loading playlist [C:\Users\ronen\SDRTrunk\playlist\police.xml] [17MB/29MB 60%]
20220730 225720.297 [main] INFO i.github.dsheirer.gui.SDRTrunk - starting main application gui [22MB/29MB 76%]
20220730 225731.623 [sdrtrunk scheduled thread 3] INFO i.g.d.c.c.ChannelAutoStartFrame - Starting [1] now - timer invoked [63MB/79MB 80%]
20220730 225731.676 [sdrtrunk scheduled thread 3] INFO i.g.d.a.c.mbe.JmbeAudioModule - Loading JMBE library from [C:\Users\ronen\SDRTrunk\jmbe\jmbe-1.0.9.jar] [26MB/79MB 33%]
20220730 225731.684 [sdrtrunk scheduled thread 3] INFO i.g.d.a.c.mbe.JmbeAudioModule - JMBE audio conversion library loaded: JMBE Audio Conversion Library v1.0.9 [26MB/79MB 33%]
20220730 225731.685 [sdrtrunk scheduled thread 3] INFO i.g.d.a.c.mbe.ImbeAudioModule - JMBE audio conversion library IMBE CODEC successfully loaded - P25-1 audio will be available [26MB/79MB 33%]
20220730 225731.706 [sdrtrunk scheduled thread 3] INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [29MB/79MB 37%]
20220730 225732.839 [sdrtrunk polyphase channel] INFO i.g.d.a.c.mbe.AmbeAudioModule - AMBE CODEC successfully loaded - P25-2/DMR/NXDN audio will be available [85MB/111MB 77%]
20220730 225812.548 [sdrtrunk scheduled thread 1] INFO i.g.d.s.t.m.FrequencyErrorCorrectionManager - Auto-Correcting Tuner PPM to [-2.7] [109MB/161MB 68%]
20220730 232106.006 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Application shutdown started ... [234MB/327MB 71%]
20220730 232106.017 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Stopping channels ... [240MB/327MB 73%]
20220730 232106.018 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Stopping spectral display ... [240MB/327MB 73%]
20220730 232106.020 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Stopping tuners ... [241MB/327MB 73%]
20220730 232106.021 [AWT-EventQueue-0] INFO i.g.d.s.t.m.DiscoveredTuner - Stopping Tuner: RTL-2832 USB Bus:1 Port:2 [241MB/327MB 73%]
20220730 232106.021 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Shutdown complete. [241MB/327MB 73%]
20220730 232106.021 [AWT-EventQueue-0] INFO i.g.d.log.ApplicationLog - Stopping application logging [241MB/327MB 73%]
