SDrtrunk missed transmissions
Bonkk083
Union, SC
I am monitoring two sites with one SDRplay RSP1B it gets the 10MHz but one site the aliases I miss transmissions are pick up are don't show slow but when I adjust the LNA or RF gain or move the ppm it picks up then after a few times then I have to do the same and I tried it just with just one site and does the same thing, What might be the problem?
Whiskey3JMC
Airwave Bandit
Southeast PA 🇺🇸
Change where it has 1.9 should it be 0 I just changed it but I got it to -0.2ppm
This number (Measured Error) needs to be as close to zero Hz as possible (it will jump up and down in small increments once set) so adjust the PPM number up or down accordingly until you find a sweet spot close to zero
C_615
Make sure the enable decoder to auto adjust ppm box is unchecked. Type in 0 in the PPM box.
