EdwardClerkRudolf
headless operation?
I have SDRtrunk running on a slightly overclocked Rpi3+ using 3x RTLSDR dongles monitoring a P25 Phase 1 system and providing a feed to broadcastify. It is running very well but I am trying to get the setup to be more robust. I understand that it won't run headless because it needs various GUI bits to work right. I use RealVNC to access the Pi and minimize the waterfall GUI after I manually run the command line. Minimizing the GUI window saves about 100% on the top cpu counter. ((190% with GUI up, 90% minimized, then about 100+% for each call).
Is there any method by which I could start SDRtrunk up at boot or am I completely limited to manually typing in the command line from a GUI window every time? Is there a way that say VNC server starts up the GUI interface and would give SDRtrunk what it needs? Would screen work? I have it set to boot to GUI. But I need a way to put the command line in rc.local or similar. Can I fire off a VNC connection from the pi in which SDRtrunk runs and to which I could connect? If I plugged a monitor into it would that solve the problem? It ability to access the waterfall from a running program is useful. I also want to be able to monitor if the program has crashed (low cpu) and autorestart.
ECR
ECR
