SDRuno updated to Version 1.1
ki7fk
#2
I agree! This is a very nice update. Now, if someone could refresh my memory as to how to enable the audio output from SDRuno to the the Virtual Audio Cable, it would be most appreciated. I looked everywhere (obviously not quite everywhere) and cannot seem to find the menu for that setting. I had it working great with the previous version. Thanks!
mbott
Delaware County OH EN80nd
#3
From the SDRuno RX Control module, click SETT. Navigate to the right into the CAT tab. Set the appropriate COM DEVICE.
I believe that's how it is done. Haven't used a VAC yet.
Mike
#4
Open the settings panel from the Rx Control Panel and select the OUT Tab, then select whichever VAC you have installed under WME Output device. This will only take effect after you have stopped and restarted the stream
