Good Morning.
I’n still learning more about this radio as I go. Today I have two questions.
I have started to play around a little with some of the display options. While it’s interesting for indoor use, I have noticed that it is pretty much impossible to read anything on the display while outdoors! Does anyone have a recommendation on how to remedy this?
I realize that these new radios are designed to not receive anything when an ENC transmission comes on. I also realize that the little ”ENC” indicator comes on. To clarify, I’m not asking about receiving, decoding, or listening to transmissions that we can’t listen to. But is there anyway - a “hack?” Or modification…or…to turn this off? Here’s why. We have all experienced hearing an agency do communications where one side is ENC and one is not. Simply put, doing a side by side with a radio that can get the garbled noise and the 100, it would seem that the 100 is not quick enough to pick up the clear half The way it is configured now. Personally, I’d rather have the ability to “log” (if you will) what it is I’m receiving then simply push the “avoid” button!
Thanks!
Thanks!
