SDS 100 Multifunction Knob Malfunctioning.
BaLa
4GRC+83; Temple, TX 76502
Lots of issues with this scanner.
First the Solder Joint and now this..
Multifunction/Volume Knob keeps malfunctioning.
Sometimes it works right but more often than not it's doing this.
It's the same in the menu it just goes up/down and back up.
Or down up back up
Any ideas...hopefully something I can do myself?
I did just figure out I can sometimes adjust the volume If I keep it pressed down.
jonwienke
More Info Coming Soon!
VA
Knob issues are one symptom of the solder joint issue. All of the signal lines from the knob pass through J401.
kruser
Well Known Member
W St Louis Cnty, MO
I never counted the connections on J401 but doesn't it contain at least two rows of 25 or 30 connections for 50 to 60 total solder points?
That's a lot of possible signals that may be passing through that one connector between the two boards.
jonwienke
VA
It's a 40-pin connector, so 80 total solder joints.
kruser
Well Known Member
W St Louis Cnty, MO
That's a lot of potential signals that could be flowing through the connector!
It sure would be nice to have a service manual or even just a schematic so you could see exactly what is on each pin.
