SDS100/SDS200: SDS 100 noise. EDACS
chrisromero
¯\_(ツ)_/¯
Was wondering if anyone has tricks on how to get rid of this interference noise. This is listening to an EDCAS system in Las Cruces, NM. I have posted the video when it sounds distorted.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
The part in the middle (0:11 - 0:15) that sounds like water dribbling is interference from another transmitter, could be nearby you or nearby the tower site. Attenuation might help.
Everything else in that transmission is just how EDACS is, and even professional radios sound like that (including the interference, might I add).
Ubbe
Stockholm, Sweden
Another transmitter interfering for sure. Try the different filter settings of Normal Inverse and so on and also IFX.
It's easy to get interfered but the frequency that interferes can usually be moved by the filter settings and IFX.
Interference test
/Ubbe
Theo
New Port Richey, FL
I can't tell with the glare how many bars you have it might also just be a weak signal.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Bars don't appear in replay mode. Signal itself is heard loud and clear so I wouldn't surmise a weak signal. Definitely intermod from another station
