I have posted on here roughly a month ago regarding my SDS-100 that was getting poor reception. It was ordered from Amazon. I have returned it and repurchased through Uniden directly. It unfortunately came with all the same problems the Amazon one had. Poor reception and boot text was different.
Contacted support and the gave no comment as to why the boot up text had changed or if this was a newer updated model.
they stated I should send it to be repaired. Just before I packed it I was noticing it stopped picking up all together. My older sds100 was chattering away on my local FD channel and this newer one was silent. I updated support and they passed along everything to the repair department.
I have just gotten it back today and unfortunately it’s still not picking up anything other than just standard analog. Signal on my local repeater was better though it’s just not picking up anything. I listen to Portland anyway 98% of the time. Signal is showing -80 to -90dBm which comes in crystal clear on my old one. The only other thing I can mention is that even though the signal can be pretty decent is that is cycling through all the frequencies on the site. Something I’ve never noticed the older one do except for when the signal goes complexly dead. I’ll update this later if I can think of anything else
So to summarize it’s seems only analog is picking up, nothing digital is coming thru at the moment regardless of signal strength. Portland, which is roughly 20 miles away is getting a fair amount of reception but it’s just cycling thru the frequencies on the site. All in all reception is a little better than it was before repair.
I have the standard Uniden antenna
REM-820
REM-920
Repair slip stated following parts were fixed or replaced:
Q2
Q3
Q4
No idea what any of those are
REM-820
REM-920
Q2
Q3
Q4
