Curious what the orange wire is for on the power cable. I could not find any reference to it in the manual that comes with the scanner. I'm hoping for ignition sense as I would like to connect it that way but I doubt if I will be that lucky.
-Curious what the orange wire is for on the power cable. I could not find any reference to it in the manual that comes with the scanner. I'm hoping for ignition sense as I would like to connect it that way but I doubt if I will be that lucky.
Connecting DC Cable with Orange Wire
Connect this cable to the vehicle’s electric system that receives power when you turn on your
headlights. Now your scanner’s display will automatically dim when you turn on the headlights.
-You sure about that?
-Page 17 in my printed SDS200 manual describes understanding location, range and services.
Here's a copy of the 2018 SDS200 owner's manual that's linked from the Bearcat Warehouse site that shows the orange wire info on page 17.Page 17 in my printed SDS200 manual describes understanding location, range and services.
It is for dimming the display when you turn on your headlights. It gets connected to the output of your headlight switch, or... If you can run a wire out to either headlight POSITIVE wire so it gets +12v when your headlights are turned on.Curious what the orange wire is for on the power cable. I could not find any reference to it in the manual that comes with the scanner. I'm hoping for ignition sense as I would like to connect it that way but I doubt if I will be that lucky.
It's not in the printed manual (2019) on Unidens site @JoeBearcat ??? Why is that? Why was it removed?
No mention at all on orange wire at all.
Did you ever find out?I don't know but I will find out.
