SDS100/SDS200: SDS 200 slow GPS
Jakeguy24
I travel with both an SDS100 and SDS200, both using the uniden bc-sgps kit. The sds100 always finds the gps signal within a minute or 2. The sds 200 doesnt. Sometimes it wont find the signal after 5 minutes, ill have to turn it off and back on. Ill sometimes have to repeat that process a couple times before it finds a signal. both gps pucks are within 12 inches of each other on the dash. Ive tried swapping pucks, and tried swapping the locations of the puck, with no difference made.
Anyone else experience this, or have any idea how to fix this? Is there a better aftermarket gps unit i could be using for the sds 200?
dave3825
Suffolk County NY
Not sure then. I just checked my 200 and its set for 4800, and while that's the default setting on the 200, it worked 2 months ago when I used gps on it.
nessnet
Eastside of Lake WA
My experience: (both radios and their GPS next to each other)
The SDS100 with it's puck (basically a BR-355S4) acquires GPS lock fairly quickly.
But, an SDS200, with the CB-GPSK takes considerably longer.
I always thought that the CB-GPSK just had lousy sensitivity.
Your situation makes me thing maybe it's the radio also.
Anyway, I have experienced an SDS200 taking way longer to acquire lock myself.
In your case if the GPS module is basically the same, this points to the radio.
Which, if this is the case, there isn't much that could be done.
kruser
Well Known Member
W St Louis Cnty, MO
I have a 200 and a 100 with identical favorite lists and profiles minus the opening message which is the only difference in programming between the two.
They both contain the same favorite list which totals 96 favorites.
The SDS100 boots up and starts scanning 16 seconds faster than the SDS200 does.
I always figured there's maybe a different processor in the two or perhaps the 100 is running at a faster clock speed.
Oh, the SD cards are also identical 16GB Sandisk Industrial micro sdhc cards bought together. This tells me there is a difference between the two models. The USB sections could be different between to two models in the boot time case but something tells me something else is responsible for this slower boot time on the SDS200.
Perhaps the slower GPS detection is somehow related to the noticeably slower boot time between the two models.
I recall someone else saying something about their SDS100 also being faster to boot than their 200 but I didn't follow that thread.
I've never measured GPS detection times!
JoeBearcat
Uniden Representative
Twp GPS pucks in close proximity will sometimes interfere with each other. Keep them at least a foot apart.
donc13
Grand Junction, CO
I don't have an sds100 but do have an sds200. I timed the startup from power on to scanning. 18.27 seconds. I load 1 favorite list only and do have gps. I scan 5 counties but 95% all the traffic from those counties is on out state DTRS system (5 nearby towers) and BLM, FOREST and a few other federal agencies. All with location control on via gps. Since the radio retains the location where it last was, it does not have to wait until it gets a gps signal.
Not knowing what you are loading on your radios, I can't imagine an sds100 booting up 16 seconds faster.
kruser
Well Known Member
W St Louis Cnty, MO
My SDS200 takes 44.2 seconds from power on until scan.
My SDS100 takes 30.0 seconds from power on until scan.
I took the SD card from the 200 and put it into the 100 for this test. No GPS enabled or hooked up on either model.
So both models were loading the exact same data from the same SD card. It consists of 96 favorite lists but only one is enabled. Disable the enabled FL to get a Nothing to Scan message results in the same timing as when a favorite is enabled.
The SDS100 has either a faster data bus for reading the SD card or it has a faster processor. I've never looked up specs to see if the two models use the same exact processor or not but the 100 is noticeably faster to boot to a ready state. This was also noted by others after both models were available for purchase as well.
Ive never tried to test scan rates between the two models but if that is the same, I think it indicates the faster boot on the 100 is due to a faster data bus for the SD card.
Uniden's SD card models seem to use USB 2.0 speeds while the GRE designs seem to transfer using slower USB 1.1 speeds. That's from tests I did with a GRE PSR800 and TRX2 years ago now. This was the USB speeds between the scanners and the host computer and not related to the boot to ready time of the respective models tested.
Either way, the boot time is not a big deal. I have plenty of things to get ready while the radios are booting up!
They all scan at a rate that seems plenty fast for my needs.
Ubbe
Stockholm, Sweden
There was one bug in the SDS100 firmware, and then probably also in SDS200, that made the scanrate be 45ch/s for a couple of years. Then in some recent firmware upgrade, maybe 6-8 months ago, they fixed that bug and now I measure 78ch/s in a SDS100E.
I'm pretty sure that they use the exact same processor and DSP in both SDS scanner models, but the SDS200 have some extra functions in its firmware like the network port handling that could need some extra time to setup and detect a router and look for external commands and so on. The more hardware to manage the longer it will take for the firmware to check and validate that hardware.
If having both models you can time it takes to load all favorite lists from the state where all are unselected. That would show the SD card interface speed.
/Ubbe
dave3825
Suffolk County NY
Wow, and I actually thought mine was slow.
My 200, set to load 4 fav lists, takes 20 seconds from power on to start scanning. 2434 total freqs and 1018 talkgroups.
With no lists enabled to scan, Power on to Nothing to scan is just under 8 seconds.
Something does not seem right there.
Brejames1
im a new rrdb user and a ham i have a sds200 i want to put on a gps to travel about 300 miles north one way couple times a month i watched a couple you tubes on setting up the gps my question is after you set the baud rate do you just start scanning and the gps does rest? my buddy said i would have to put all sites in between me and my destination in please help thank you
73's
jm
donc13
Grand Junction, CO
73's
jm
Simpler than that. Buy Uniden's GPS kit,
Plug the GPS and set location control on,
set range to 10 miles,
Turn on nationwide scanning, turn favorites off,
Select the service types you are interested in,
drive away.
Brejames1
drive away.
Thank you73's
nessnet
Eastside of Lake WA
Assuming you take the same route every time?
If it were me, I'd take the time to build favorite lists for just what you want to hear along the route, (like law enforcement).
Otherwise, you will hear everything.
Yes, you can control this via selecting your service types, but it is always better (and much more accurate and faster) to have FLs built.
Take it to the next step and program rectangles and then (depending on what global range you set), the radio will switch right as you cross a state/county/city border. Only listen to the systems/departments in the area you are currently in.
donc13
Grand Junction, CO
You and I will have to disagree on this I put close to 10,000miles/yeae on my RV. All over the USA I use the method I described and am very satisfied. I care about incidents on the road ahead of me or incidents near the campground where I am spending the night
I have yet to come across a traffic incident that I wasn't aware of.
Prior to the SDS, I had a 396T and programmed 48 banks one for the major agencies in each state. I had to remember to turn banks on and off as I drove.. a real Pita although it worked.
nessnet
Eastside of Lake WA
You are traveling about in your RV.
The OP (I assume) is driving a fixed route.
Completely different situations.
Last summer, I drove across aprox. 2/3 of the US.
Of course in that situation I used database with GPS scanning.
But, I also used to drive the same Interstate for 350 miles (one way) almost every month for a number of years, and then, I most certainly built favorite lists for the entire route. And, with rectangles, the radio switched to the local LE as I crossed into each county as I traveled.
donc13
Grand Junction, CO
Yes, in my RV.
For driving a fixed route... sure.
Multi-state wandering, not so much.
So I guess we do agree
