baker50021
I am using location control on my SDS100 with favorite lists downloaded from the Master Database in Sentinel. Is there a way to only download the Control Channels?
I agree. While there is a one megabyte size limit on a Favorites list on the x36HP & SDS series scanners, you can have multiple Favorites lists, so the capacity for programming is all but unlimited.On SDS scanners, I cannot think of a good reason to not program all of the frequencies associated with a site. Uniden probably had a good reason to include programming all of them, rather than those marked as control channels. In previous models, where memory limits were more tight, yeah you had to be careful how much "stuff" you programmed. SDS scanners have lots of memory.
I have heard that by scanning ALL the frequencies on a site will slow down scanning. By selecting only the control channels you are scanning less frequencies. Is that not the case?On SDS scanners, I cannot think of a good reason to not program all of the frequencies associated with a site. Uniden probably had a good reason to include programming all of them, rather than those marked as control channels. In previous models, where memory limits were more tight, yeah you had to be careful how much "stuff" you programmed. SDS scanners have lots of memory.
Just for the point of saying it, scanning trunked systems is different than conventional. Once the scanner detects a control channel, it "remembers" it and stays with it. Only if the signal strength falls off will the radio scan for another control channel, which takes very little time.
It only finds, then focuses, on the active control channel’s signal. The next time, and thereafter, when that system (site) comes back up during scanning, it will go back to the last control channel found on that site. If (or when) the control channel changes, rotating to a different frequency, the scanner will look for the replacement then keep returning to that frequency as the system comes up in the scanning cycle.I have heard that by scanning ALL the frequencies on a site will slow down scanning. By selecting only the control channels you are scanning less frequencies. Is that not the case?
