n0wla
I have a 100 and 200 both programed identical. In side-by-side comparisons the 100 out receives the 200 by a lot. Anyone else ever experience this?
Certainly can't judge radio rx by programming alone. What are you using for an antenna on each? Have you connected the same antenna independently to one then the other? Is the squelch set identically on both? (not impacted by programming) You've ensured the same service types are enabled on both?I have a 100 and 200 both programed identical. In side-by-side comparisons the 100 out receives the 200 by a lot.
And my last question?Stock antennas on both, locked on same FL, SQL on 2, 100 chatters on while 200 scans with an occasional hit.
Switched 200 to outside discone with same results.
Can you post a short video or link to a video of them both in with the display in detailed mode?Stock antennas on both, locked on same FL, SQL on 2, 100 chatters on while 200 scans with an occasional hit.
