Recently have been trying to add this system: https://www.radioreference.com/apps/db/?sid=9746. As you can see, this is a NXDN Trunking System and I'm trying to program Site 7's control channel 454.065625 and the SDS 100 & 536 HP rounds off to 454.0625 and the additional frequencies of 454.215625 in which the SDS100 accepts and 536 rounds off to 454.2156 (I'll assume 25 is accepted, just not showing on the display) and 454.590625 which the SDS 100 accepts and the 536 rounds off to 454.5906 (I'll assume 25 is accepted and not showing). Duplicate programming via Sentinel, and the SDS 100 is not receiving the system's control channel and trunking the system while the 536 is. Attempted to manually enter the control channel and it wouldn't accept it, unless it was above the 454.100 threshold.
My first thought was to the Band Defaults, which I tried at both 12.5 and 6.25 spacing. No change there. Took a ride today and gave it a try in the event the signal wasn't strong enough and that did not work. Double checked LCN settings and they also are the same. It would appear, the SDS100 isn't going to trunk track the system unless the frequency is exact while the 536 (and probably the 436) aren't as picky. Taking suggestions..
