SDS100 display setting?
Zeus661
Almost Retired
Toledo, Ohio USA
Can I set the display to not light up until it stops on a signal? Will setting it that way extend the battery life? If this can be done please give directions. Thanks
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
Press Menu then scroll to Display Options and press E/yes. Yes it will extend battery life, but not by much
89579
Saint
Fort Erie Ontario Canada
This is the setting I use
dimmer=50%
Squelch Light=OPEN Squelch
Keypress light=infinite
Key Backlight=Enable
Flash with back light=On
External Power=Backlight=Off
THEN PRESS THE E YES BUTTON TO SET IT. make sure you do this or it will not work
Ubbe
Stockholm, Sweden
Not by very much. I believe the scanner takes something like 750mA when in use and the backlight takes something like 50mA. Less than a 7% longer battery life, from 6 hours to just shy of 7 hours.
/Ubbe
WeldGuy
Canal Winchester, Ohio
If you haven't figured out the answer on your own, I accidently found out how to do it on my new SDS100.
Simply give the Power (and light) button a tap. Display turned off until signal received.
billybob
San Diego
I would like to change the color of the flashing led. The purple white color is annoying.
Whiskey3JMC
I don't believe the standby light is color customizable like the alert lights are, but here's how to turn it off:
MENU > Display Options >Backlight Options
Flash w/Backlight Off Flashes the alert light every 5 seconds to let you know the scanner is still alive when the display is off.
Scroll to select On, or Off.
billybob
San Diego
Thanks for the info. I like the idea but after I tuned it on I just don't like the color. It's annoying in the dark. Thanks though
