SDS100 issues on OnQue
PA
#6
Either the system is dmr rather than nxdn, or there is a dmr system on the same frequency nearby. Are you 100% sure onque is nxdn?
The sds100 knows the difference between color code, ran, and NAC.
mclove
HAMILTOIN CANADA
#7
SDS100 uniden
yes it showing the color code 3 that wrong it should be showing ran 3 so the scanner cant track it cuz its not sure about the system i cant change it from color code to ran maybe a bug uniden need to look at that why i asked if anyone els in the gta having the same thing happend to them on the onque system whit this scanner
mclove
HAMILTOIN CANADA
#9
SDS100 uniden
yes in the database it shows it ran 3 but when i upload to my scanner the display say color code3 no ran so my scanner wont work with onque there no where to change it ran 3 in the scanner
Maryville, Tennessee
#17
your are right dave the scanner should no that so this must be a bug then
I assume you have updated the database today to get the latest NXDN additions?
You could create a favorites list for this system and import/append it directly from the database. After you have it as a favorite, you can change it to use a RAN instead of the CC. You could also check and be sure that the system is showing as a 'NXDN Trunk' system (and not a flavor of DMR) type in the scanner.
PA
#20
The system ID, site ID, and frequency shown are correct for OnQue, and according to OnQue's web site, they are definitely NXDN. So it's either a bug in the scanner, or someone is broadcasting DMR on that frequency with color code 3.
Try programming that frequency conventional / Digital Search and see what happens.
