SDS100 - Multiple Favorite List (Select / DeSelect)
Yocuz
Gloucester County NJ
Hello, wondering if there is an option to select or deselect multiple favorite list on the SDS100?
An example is Favorite List 0 thru 5 are ON or enabled. I want to monitor F0, F1, and F2. Can I disable F3 thru F5 in one keystroke command or do I have to disable or turn them off individually? I want to avoid the keystrokes 3 [enter], 4 [enter], 5 [enter]. Does a sequence or syntax exist to type 3 thru 5 enter to disable the favorites?
dmfalk
Eureka
Short answer: YES!!
Menu > Set Scan Selection > Select Lists to Monitor
You can turn on or off as many, or as few, Favourites Lists as you want, as well as Full Database.
Under Set Scan Selection, just below Select Lists to Monitor, are also Set All Lists Off and Set All Lists On, which I use Off before I select which of my lists I'll use at the moment.
Hope that helps!
