Just posted firmware for the SDS100 and SDS200, plus a new version of Sentinel that includes the functions added by the update. As usual for public releases, these updates are applied using Sentinel.
1.02.01 Sub / 1.08.05 Main (3/7/2019)
Be sure to also update Sentinel when applying this update.
This firmware update applies the following new settings and bug fixes:
- Added an "AMP OFF Timer" setting that determines how long the amplifier stays on after a transmission ends. If you hear hum between transmissions, change this from Infinite to one of the available settings.
- Added "Wide Normal", "Wide Invert" and "Wide Auto" filter options for FM performance improvement. When you pick this setting, the filter becomes weaker for interference on a nearby frequency. However, the linearity of the IF can be maintained even when there is strong interference within the band, and the reception may be improved in some cases.
- Added an option to display the filter setting when customizing the display.
- Improved a reception dropout issue where dropouts are often accompanied by "LINK" icon appearing at start of dropout.
- Improved crackling noise on analog.
- Improved the reports that some REC files created have no audio captured at replay.
- Added a prompt to exit certain modes.
