SDS100 Setting up quick keys in Sentinel
thevig
Charlotte, NC
Trying to get thru one last programming hurdle.
I have 15 favorites lists setup in a profile. I want to be able to simply switch between favorites using the keypad. I'm confused assigning a quick key to each favorite.
Let's say my favorites list is as follows:
Police
Fire
EMS
Amateur
Transit
If I'm listening to police, but want to jump to amateur via the keypad, how do I properly set up the quick keys? Thanks in advance.
eaf1956
Evansville, IN
That is almost impossible to answer not knowing how your programming is set up. If all these are in one system say (0) which would be F0 then if each of the examples is set up as a System say S0 for Police S1 for fire, S3 for EMS, S4 for HAM, S5 for Transit. then each can be turned on and off with either 0.1 to turn on/off Police or alternately .1
Of course there are many ways to program the same thing and each may be assigned as Departments and not Systems.
Here is an example of one of my favorites shortened for brevity.
Favorite List named "Evansville Area" assigned as F0
Some systems in the FL: Vanderburgh CO assigned S0, Indiana Safe T assigned S1, etc etc for S2, S3, S4
System S0 had departments assigned: Evansville Police D0, County Sheriff D1, Evansville Fire D2, County Fire D3 etc, etc
In this case to turn on/off say County fire I would use 0.0.3
For a Dept in SAFE T on System S1 as an example Warrick Co in my programming is assigned D5
So to turn Warrick Co on/off I would use 0.1.5 the numbers being Favorites list 0 System 1 and Department 5 or 0.1.5
Once you get your head around the hierarchy it isn't that difficult
