Sds100 went into a puddle of water
bmendez
Enterprise AL
Sds100 went into a puddle facedown speaker got wait but volume has returned how to dry out speaker again
Ubbe
Stockholm, Sweden
Paul Optiz had that scanner out in the rain. Isn't supposed to be a rubber membrane that protects the speaker?
/Ubbe
KR3LC
Pasadena, Maryland
I don't believe it was submersible so it's survivability depends probably on how deep and how long in the water. Maybe also if it fell from some height into the puddle there could be physical damage affecting the speaker.
donc13
Grand Junction, CO
The SDS100 is water RESISTANT (not waterproof) so it won't be damaged by drops of water as long as the protective covers are on the ports. As long as it just fell into a small puddle and you immediately picked it up and shook the water off, it should be fine.
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
I left a 436HP out in the rain once. Ended up dismantling it and leaving it by a fan for a quick dry. It worked as if nothing happened afterwards.
