There have been a few units where the rubber was torn or worn. No huge problem meaning most units in service are still in good condition.
After wanting a scanner for 25 years the SDS100 my first purchase. I've been running Unitrunker 1 on a RTL-SDR dongle for about a year and found it interesting enough to go ahead and get the SDS100, primarily because the Palm Beach County P25 system went to phase 2. The radio performs flawlessly for me and I'm in love with it. I've ridden dirty with it up to Orlando twice so far and I can get Orange County, Seminole County, and Osceola County from basically any part of Orlando. Locally in Palm Beach County, I can get the airport and the regional air traffic no problem, of course the county's systems come in flawless, and I can even get rail sometimes even though I'm only using a RH77CA in my house.
I would love to see some sort of audio AGC (volume leveler) implemented. As others have mentioned, there can be substantial volume jumps across systems and departments. My hunch is it's somewhat based on which vocoder is being invoked (and of course analog). I've read it was attempted on one of the earlier models and didn't work well, but I suspect this radio has enough CPU to be able to do it.
-E
You can just the volume on channels
Hold on channel
Function button then zero (LVL)
The problem is it's not just a volume discrepancy from system to system, inside of a single system there can be substantial volume differences across talkgroups. I believe the granularity is there to be able to adjust at the department level (I usually program thru Sentinel) but it'd be a little tedious on large systems and harder still to manage when on the road.
It's a minor thing for me, it was more along the lines of "here's the one thing I wish it had", and I know AGC implementation is pretty well known if there's CPU left to handle it.
-Jeff
I have been using my SDS 100 for several months. After exchanging my first radio for a second one (due to low sensitivity) I believe they have struck a balance between sensitivity and selectivity. Especially in the congested 800mhz range. Cell site front end overload is a huge impediment.
That said....I would appreciate better performance on the narrow-band VHF-UHF area. S/N is rather poor in that range.
On a non-technical note. How about some additional tutorials for users who want to load, edit and run systems from the national database WITHOUT the need to load them into "favorite lists" on a computer?
For example. If, on short notice, I fly to city X and want to program the radio on the fly. How can I do that? The zipcode feature really hasn't worked for me.
Finally. Thank-You for the beefier battery. It is good to see a manufacturer make good on their promise.
+3
+2
+1
-1
-2
-3
Hold on channel
] Costs too much right now.... And lack of 75 MHz...
Remember, he or she is from "Celtris III, A Cardassian Planet" according to their location. Their understanding of things here on earth may be lacking
Bob,scanman... Trying to understand exactly how you're programming the radio. Are you doing it completely manual like entering the frequencies for each site for a simulcast system? You are not using a computer or Sentinel at all? If so that's like trying to start a brand new 2019 vehicle with manual transmission by popping the clutch going downhill if that makes any sense to you. I guess it can be done but I think you're going to miss a few things if you don't know to put them in there with this kind of radio.
Yep I just saw your post because I was writing mine. You are right sir.Bob,
Based on comments in his other thread, he's programming manually, not via Sentinel/PC.
And you've already mentioned the reasons it's better to use a PC. Besides firmware and database updates, done through Sentinel, it's a heck of a log faster to use Sentinel for entering the doggone text tags for departments and channels/talkgroups.
