SDS100/SDS200: SDS200 and Ham Radio
rufust
Upstate NY
I have a SDS200 that was working fine then dropped Ham frequencies.I reloaded them and even put in a lone file but still will not recieve.Everything else seems to be fine.What could I have done to mess this up ?
hiegtx
Dallas, TX
Make sure that the “Ham” service type is enabled. If it is not, you would not hear those channels at all. If using a PL. tone, or DCS code, make sure those are correct, or set to “Search”.
IdleMonitor
The Ottawa Valley - Eastern Ontario
Did this happen within the last 2 weeks since this last Firmware update?
I've noticed some degredation of frequencies within the 140-144mhz range. Used to get my regular system but now the frequencies I need to get don't come through like they did before.
Hook up my 436HP and pulls in what I need. Hook up the SDS200 with the exact same programming and nothing.
rufust
Upstate NY
I did do the latest update
I wonder if the update can be backed out ?
I enabled Ham all alone and still quiet.I know there was activity because of an HT.
dave3825
Suffolk County NY
When did it drop ham in relation to the update? Before or after?
Did you import them from the db or manually create the fav list?
What does that mean? You hear ham on the ht, or your keying up on an ht and not hearing on scanner?
hiegtx
Dallas, TX
I believe after update and loaded from database.I hear activity on the Handheld that the scanner is not picking up.
Are you hearing other Vhf conventional channels without problems? And can you hear the NOAA weather radio stations?
tvengr
Well Known Member
Baltimore County, MD
Most of the amateur repeaters use 5 KHz deviation (FM). Also, the tone indicated may be for access only on the input side. The outputs often are carrier squelch (No PL tone).
