Hello all!
I received an SDS200 today and started playing with it. Had some basic trunked channels programmed in and it was receiving well.
I came back to it an hour later and it's stopped receiving anything at all. Thinking it was an antenna issue I threw it on the rooftop antenna - no dice. Tried reformatting the SD card & clearing user settings, same result.
As a quick test, I took it to the bench and fired up the signal generator. Tuned the scanner to WX mode, 162.550 MHz, and injected a 1kHz FM signal at -60 dBm. Nothing on the RSSI meter and nothing but noise from the receiver - the scanner's gone totally deaf it seems.
Curious what could've happened. Is the frontend going out a known issue with these scanners? Would be a shame to have to send it in for repair after less than an hour of use.
