SDS200 Hum Reports
K5mow
Alvin TX
Yeah and somewhere in the future you will want to sell your SDS200. The very first thing the buyers will ask is: "Does your your radio have the HUM Fix".
I understand what you are saying but I would tell them it absolutely has zero hum. Maybe I will call them and order the part but I am not gonna worry about putting it in. You got a good point at least I will have the part.
Roger
K5mow
Alvin TX
It actually may have the fix, mine has a serial number in the 400's, and came with the fix. Open it up and take a look, the only way to know.
You could be right my serial number is almost in the 400s.
Roger
N8TXX
Scanner Enthusiast
S.E. Michigan
Just because it is a 400 they have 2018 400's and 2019 400's
I assume mine is 2018? 384260880004xx.
The shop owner did a check, It arrived from Uniden at the warehouse into Lesco at South Bend on March 3rd. I ordered on April 14th, got it on April 16th. It had the fix.
PCTEK
Northern California, USA
I usually run the audio of the scanner to an external speaker. I think I read that the "Hum" is not an issue with external speakers.. Can anyone confirm that? Thanks
radio3353
I received my SDS200 a couple of days ago and it was the old stock. Meaning it was the first radios to be shipped. My particular Radio has absolutely no hum at all. If you’re put your ear right next to the speaker you here in a little. But if you are even 1 foot away you can’t hear anything. In my opinion the quality of the sound on 800 trunking and analog conventional sounds amazing. I will not even be calling Uniden for the part. I don’t believe it’s necessary at all for me.
Roger
The part is free. Order it. Some have reported the hum appearing later after some use. Better to have than not. I don't even have a SDS200 yet, but I still ordered the part. I plan on ordering a 200 well after the bugs are shaken out so I wanted to be prepared.
eaf1956
Evansville, IN
Why would you order a part for a radio you don't own. You do realize that when and if you do buy one the mediation part will probably already be installed.
Sent from my SM-N960U using Tapatalk
radio3353
The short answer is 'because I can'. Undiden offered it unconditionaly so I took advantage of it since I plan on a SDS200 purchase someday and feel it would not hurt to have a backup since Uniden's fixes have been variable. OK by you?
eaf1956
Evansville, IN
Hey if you want a useless piece of metal laying around more power to you.
  • Like
Reactions: RRR
m42duster
OHIO
Yes, external speaker is an issue.
Sent from my moto g(6) (XT1925DL) using Tapatalk
  • Like
Reactions: RRR
phask
KZZV - SE Ohio
Mine is much more noticeable with an external speaker. In fact, I have tried several, some are MUCH worse than others.
K5mow
Alvin TX
I am using a Eternal speaker from Uniden it is a non-amplifying speaker. Absolutely no hum whatsoever in mine. Even if I turn the sound way up no hum whatsoever.
Roger
eaf1956
Evansville, IN
What is the output source? Rear speaker?
Why on God's green earth would I ever feed audio online from the rear speaker or even the headphone Jack on an SDS 200?
m42duster
OHIO
So PCTEC and others can hear what it was like. He asked about noise from external speaker. I don't use data, but my headphone jacj is dead quiet, just as your data feed.
Use yer noodle. The whole thread is "HUM REPORTS".
Ubbe
Stockholm, Sweden
I think it was a product number at the beginning of the serial# and then the 260 that are the Vietnam factory and followed by the last digit of the year and lastly a digit that goes to 8 as the highest, that must be half a quarter of a year? So that 8 must be a nov-dec production date. It's possible that they manufactured something like 450 scanners in 2018 and the serial number continues from there in the beginning of 2019 with the next shipment.
/Ubbe
