I wanted to share my initial impressions of my new SDS200 and a few video clips.
First the hum. Yeah, it's there, present in a silent room out to about 2', but I don't find it objectionable and I can live with it, and I don't even feel the need to do the DIY fix, it's that little of a bother for me.
Audio is good, better than my 536, without the "muddy" sound that I get out of my 536 on some systems.
My first important test was to simply monitor Phoenix RWC Simulcast A (Phoenix PD) from my office, sitting within line of site of a Simulcast A tower where other towers are relatively far away and obscured. Sitting next to my PSR-800 (my go-to scanner for this particular situation) the SDS200 doesn't miss a beat. My SDS100 apparently suffered from some form of "interference" (concluded by Uniden, a beta tester, and others), but the SDS200 suffers no such issue. This is big for me.
My second test is also important to me. I need to know how this thing receives on UHF, as the AZ DPS is one of my favorite agencies to monitor and they use an ancient UHF system. For this test I set up the SDS200 next to the PSR-800 (one of my best scanners for weak signal UHF using stock antenna), locked onto DPS Metro South 460.275, with a transmit tower about 21 miles away. From my office reception is always "fringe" with plenty of noise and occasional drop-outs on any scanner, so this seemed a good frequency to use. As you will see the SDS200 does an admirable job of keeping up, though it does drop out a few times at 10 seconds and 13 seconds for a brief period where the PSR-800 stays solid. This is pretty typical of what I'm seeing so far, meaning that the SDS200 might be a touch short of what some older scanners might be capable of on UHF, but it's close enough for this picky hobbyist. Considering all of the things that the SDS200 brings to the table, I'm pretty happy with these results.
The display is perfect and does not flicker.
I have had no issues today monitoring multiple systems / types of systems.
Overall I'm quite happy with initial results. Some may remember that my review of the SDS100 was not as kind, but I call them like I see them and I'm pleased to share a very positive initial report from Phoenix.
*Next up some serious head-to-head testing vs. some of the best analog scanners ever made, all hooked up to a Stridsberg multicoupler and a Diamond discone at 30'. I will be testing VHF, UHF, VHF civilian air, and milair there, and will then pit the SDS200 (hooked to the discone where it can receive signal from every tower in the simulcast at once) against the Unication G4 + stubby. While I don't expect the SDS200 to match my BC780XLT on milair or VHF, or my Pro-2006 on UHF, if it's even close that's a clear win for a Swiss army knife scanner in my book. If it can come close to the G4 on simulcast with the rooftop antenna I will be beyond thrilled. Stay tuned for the results on those tests this weekend.
