SDS200 outdoor antenna
CT
good outdoor antenna for the SDS200
That totally depends upon which bands you monitor.
Different antennas work better on certain bands.
donc13
Grand Junction, CO
There is no such thing as "best antenna" as it depends on which frequency bands you are interested in, how far you are from the towers from the services you wish to monitor, how big an antenna you would like, and so on and so forth.
Give us more information on what you wish to listen to and where you are and what types of systems you are near.
n1chu
Farmington, Connecticut
Since you didn’t specify what bands you were primarily interested in I assume you are asking for recommendations for just one antenna that covers all bands. And that means there are compromises… much like the stock rubber ducky antennas that come with an all band handheld scanner.
n1chu
Another way to approach this is to make a list of what you want to listen to. Then see how many on the list can be heard with the stock antenna that came with the scanner. If you can receive all clearly, keep your money. If you can’t get all, try monitoring outside the house, possibly on a back porch or deck with the stock antenna. (Some dwellings might have metal foil insulation battings that will make your house act like a faraday cage, reducing signal strength. But in general, all outside antennas will do better than the stock antenna while inside the house. If you hear all clearly you have just answered the question of “Do I need a more expensive antenna that touts a lot of gain?” The answer would be no. You could try a cheaper antenna or a mobile antenna. (Some outside antennas are just that, a mobile antenna but with the addition of radials. If you hear some signals that are weak, a better quality antenna may be in the mix. A discone is usually your best bet for decent coverage on all bands. It’s omnidirectional but has no gain, not that gain is important if you are lucky enough to have good signal strength at your location. If you do these things I mention here, then report back to this group, we will have a good idea of what you need in the way of an outside antenna. In any case, when installing an outside antenna onto a house, follow all the rules that apply. Stay clear of any overhead power lines and make sure an approved ground is included. (That’s usually a 4-6 foot copper rod sunk into the ground to which a wire is attached which connects to the mounting hardware of the antenna.
Brales60
Punta Gorda, Fl
Running a Omni X myself 20' up outside, and works great. And to add to what @n1chu said, don't forget about lightning protection. I'm one of those with the foil/insulation everywhere and I didn't anything inside my house.
