SDS200 SDS200 possible keypad backlight issue?
werinshades
Chicago , IL
I shut off the light in my scanner area last night and tried to get a cell phone picture, but it didn't capture what I was seeing with my eyes. Besides the SDS 200, I have two 536's, two 996XT's and one 996P2. The 996XT's had a brighter display than the other four scanners, but they all were visible under a no-light condition including the SDS200. I could easily navigate the key pad on all scanners. Just an observation from the past mobile/base line-up.
Evansville, IN
I like the dimmer keypad. That was one thing I didn't like about the 536 was those silly keys being so bright.
That being said I still think the keypad should turn off when the display does. The sds 100 does, why not the sds 200?
Menu in the 100 says enable/disable while the 200 is on/off.
Sent from my SM-N960U using Tapatalk
maus92
Annapolis
Wouldn't it be a great idea for the next scanner model to have the keypad backlight being driven from the display backlight circuit, so they both would be adjusted by the users preference? And whatabout a light detector /photocell to help adjust the display backlight in a vehicle when driving into a tunnel or dark area or when you have different light levels in a room depending of if the sun are behind a cloud or not.
/Ubbe
For a mobile radio, I think that you would want the display and keypad illumination to be independently adjustable, and that a fixed keypad illumination doesn't work for various reasons. I can see circumstances when keypad illumination might be too bright, but again some users may require a brighter level to compensate for poor night vision.
maus92
Annapolis
Then how do you explain the obnoxiously BRIGHT and FLASHING Lan/Link lights on the FRONT panel?
Seriously, who thought this was even a remotely good idea?
Those lights are FAR brighter than my Keypad, and of no use to anyone.
Those lights are pretty much standard on the ethernet jacks of networked devices, and do serve a purpose. However, there are devices that allow those lights to be disabled. Perhaps a firmware revision could address that if the part Uniden used allows for it. The lights are not an issue for me.
maus92
Annapolis
Or give the user the option to turn off the keypad lighting. I can see circumstances when having the keypad glow while the display is off would be useful.
Cleveland, OH
I received two scanners yesterday, one for me and one for my friend who shipped his to my house because I was home yesterday. Our serial# are 1 digit apart. My scanner is the one with the 996P2 and his is the other one. I programmed both scanners with the same settings, keypad backlight on. There is clearly a difference.
I was looking at these pics again, prompted by the promo photo of the SDS200 with everything depicted as glowing brightly (including the LAN lights with no cable plugged in). Not only is the keypad backlight very dim, but also the volume knob and the 3 buttons under the display. I just noticed this.
teknishun
Alvin, Texas
......(snip)......
On a side note, both units had the buzzing/humming noise coming from the speaker with the volume turned all the way down. The buzzing noise was not audible unless you put your ear to the speaker. I wasn't concerned about it on the units I tested. However, I do realize this is a bigger (louder) issue with other units.
My SDS200 has that hum from the speaker as well ONLY IF I put my ear to the speaker. It kind of sounds like a small
motor or something running in the background. Under normal operation that sound is totally inaudible and I cannot
see this being a big issue for anyone. For what it's worth my 536HP makes a similar noise and always has.
The keypad backlight issue is different - too dim with the lights off in the room. Can't be seen at all in the daytime.
maus92
Annapolis
I agree with your characterization of the hum/noise "issue" - the only time I can hear it is if I put my ear within inches of the speaker. I can see where this might be an issue with a powered external speaker, but not with the internal or an unpowered external speaker. The unit's audio power is more than adequate in my noisey vehicle.
As for the keypad backlighting, I'm not sure if this is a defect in some units or the variability of individual eyesight and / or preference. My workspace is always dimly lit (computer monitors, device display screens and task lighting provide the only illumination) and I can easily see the backlit keys. The SDS200 display screen in this space is set at roughly half of full brightness
osiris
Doylestown, Pa
So I got my SDS200 yesterday and so for I love it, BUT, the keypad is definitely not bright AT ALL. The one on my 100 is a lot brighter.
My 200 does not have the "hum" problem and I guess I can live with the dim keypad because I don't usually mess with it at night. The only way I would is to toggle systems on or off. Once I have on what I want to listen to I usually leave it scan. The hold buttons are fine so I can stop on a transmission or system or dept if I choose. That being said the keypad should be brighter AND be controlled with the display brightness IMHO.The keypad is hardly visible at night.
The volume and clarity of voice on my local phase 2 simulcast system is fine and on par with my SDS100. Still getting everything set up the way I want it, but very happy so far.
Bob
weathermedic
NYC
Here is a pic I took of mine in total darkness (indoors) with the screen backlight setting on high. Pic taken with an iPhone 8 plus with flash off. Serial # ends 0976. Could it be a little brighter (on par with 536, yes) but it's more then adequate for me. This would be bright enough in a mobile installation as well.
maus92
Annapolis
Here is an ipad pic which basically captures what I am seeing at the scanner rack.
That's is a good representation of the different illumination levels between the radios, and the SDS200 is more subdued than earlier models. The keypad light level looks to be useable in your installation.
wise871
Florida
I would be happy just to get my numbers more illuminated but Uniden isn’t even willing to help anymore. I don’t care about camera settings. The images I posted best represents what I see in a dark room with my own eyes. Thanks Uniden for taking care of your customers.
maus92
Annapolis
I would be happy just to get my numbers more illuminated but Uniden isn’t even willing to help anymore. I don’t care about camera settings or exposer. This image best represents what I see in a dark room with my own eyes. Mine is the bottom scanner. Thanks Uniden for taking care of your customers.
The screen also looks slightly brighter on the upper radio - are these radios stacked on top of one another?. Will your retailer provide an exchange? - that is your first option - have they rejected an exchange? You say Uniden isn't willing to help - have they examined your radio in their repair facility? We know that Uniden has designed the keypad lighting to be more subdued than earlier models, but based on the image, there is a difference between the keypad backlighting of the units (also a difference in display brightness which might be affecting the exposure of the image.)
dfw1193
Venus, Texas
ki
I just still dont understand why or what use the keypad light is since when you press the menu knob the display lights up making the keys visible anyway.
wbigcount
Kansas City
ki
Pressing the menu button doesn't change the keypad light brightness on mine, and for me, the display is always on. Still can't see what key is what.
