Hello all,
I just purchased a used but good condition SDS200. I’m familiar with the Sentinel software since I have a 536. I received the scanner and swapped it out with my 536 and used the power supply for that scanner. The SDS200 powered on and seems to work perfectly except it will NOT pick up any signal no matter how strong it is..
The weird thing is when I switch out the power cable with the one it came with, it works perfectly fine.. My confusion is also due to the cables being identical in model numbers… I have tried multiple other cables with no luck. I’ve also formatted the SD card twice now and even manually programming a analog frequency makes no change. Any thoughts? Has anyone else had this sort of issue??
