rocky28965
Can anyone tell me if the SDS200e comes programed with the US frequencies, same as the SDS200 ?
OK, let me clarify that about not coming with systems programmed. The SDS200 (US and Canada versions) come with an old copy of the US & Canada Radio Reference Database installed.From the video's I have seen it appears to be pre-programed with US Law Enforcement & Utilities.
SDS200 Beginners Guide - YouTube
I am in New Zealand & have no need for any of that.
I believe there is a Australian Version, setup similar to the USDS100, but is not listed on Uniden AU.
The USDS100 is available in NZ & Australia & dosent have the US programing.
I could buy one of those but prefer a desktop unit.
There is a UK version also SDS200E.
I have been unable to find much info on the differences other than the frequency & plug on the AC Power.
On the SD card you have a folder called HPDB. In there you can delete all files that have a .hpd extension. There will only be some 200KB of files left. If you delete all files it will throw an error and refuse to startup. The whole database are only some 200MB so it doesn't need to be deleted. You will have to fill up the scanner with a lot of channels until you run out of memory.Is there any way to remove that database?
Would that be the same with the BCD536 model?On the SD card you have a folder called HPDB. In there you can delete all files that have a .hpd extension. There will only be some 200KB of files left. If you delete all files it will throw an error and refuse to startup. The whole database are only some 200MB so it doesn't need to be deleted. You will have to fill up the scanner with a lot of channels until you run out of memory.
/Ubbe
It's hardly worth the effort to delete the database files on the SD card. The total size of the entire North American database on the SD card is only 51.5 MB. The entire file structure on the card needed for the scanner to operate including the database (before adding any of your customized data to it) is only 53.2 MB.Is there any way to remove that database?
Yes.Would that be the same with the BCD536 model?
I was curious as well, so I just installed and updated a copy of the SDS200E Sentinel program, and it has the same database in it as the SDS200 Sentinel version. (USA and Canada).Can anyone tell me if the SDS200e comes programed with the US frequencies, same as the SDS200 ?
Yes. 436 536 SDS100 SDS200 are pretty much identical in functions. Uniden doesn't reinvent the wheel, they reuse the same firmware code in those scanners and only change what's needed to support the different receiver in SDS scanners and the additional features it needs like filter settings. It's the same Sentinel and database and the way how it handles the configuration files.Would that be the same with the BCD536 model?
The SDS200 (no idea on SDS200e) does not come with any systems programmed.
The SDS200e is not legal in the US due to it not being FCC certified because of the frequency bands it covers.
That doesn't mean there aren't European models here, but most (if not all) European stores won't ship to the US.
