I'm enjoying my new SDS200 and have it hooked up to my computer using the microUSB port (running ProScan) and to my router with an ethernet cable. FWIW the old iOS Siren app does actually work with my setup although it's hit and miss if I get audio through the iPhone (iOS17.2 on an iPhone 13 Pro). I have not done any tweaking, just set the scanner up for DHCP and entered the IP address in the app and it connects without problem. It only displays in landscape mode which can be annoying if trying to use other apps. I haven't found a way to change to portrait mode.
For the SDS200 experts, I was wondering if there is a way to force the scanner into serial port mode so I don't have to select it every time I turn on the scanner. Also, is there a way to speedup the database load on startup?
RV
RV
