See a HomePatrol-1 in Action LIVE!
KC9NEG
Indianapolis, IN USA
I've put up a justin.tv live channel of my HP-1, which also runs my RR feed (it's doing both in parallel). It will be up over the Labor Day weekend--not sure about after that...
This is the RR feed:
Marion County Police Dispatch Live Scanner Audio Feed
This is the justin.tv live channel:
IndyScan on Justin.tv
Hope this helps anyone considering a purchase decision. Mod's, please delete if this is "out-of-bounds". It's the same audio as my RR feed, in compliance with RR's feed broadcaster TOS.
KC9NEG
Correction: This is a two-hour video loop, unless I restart a live broadcast. Justin.tv works a bit differently than ustream.net, which I've used in the past.
KE4ZNR
KE4ZNR@radioreference.com
Pretty cool idea Todd! Now we just need to wait for a live video of the live audio of a live pursuit :D
Happy Monitoring
Marshall KE4ZNR
